vibration in car with a/c on
Old Aug 26, 2002 | 07:05 PM
fourspeed's Avatar
has anyone come up with a fix on how to stop a/c belt vibration on cars with drive side mounted compressor. i have tried tightening the belt so hard i almost roll the car over, i have tried loose, i have tried extra short belts but cannot seem to come up with the correct combination....an ideas?
thanks
terry
Old Aug 26, 2002 | 07:38 PM
Vettetrax's Avatar
Car: Camaro Z28
Transmission: auto
i have that EXACT problem.. can someone please help?
Old Aug 26, 2002 | 10:13 PM
eightTfourTA's Avatar
Car: 84 T/A
Engine: 305HOL69
Now I feel relieved that i'm not the only person fighting this same problem! I've seen this happen on every driver's side V-belt compressor i've ever watched operate, and it does make a lot of vibration. My belt deflects so badly it whacks the upper mounting bolt on the compressor bracket. You'd think GM would have made an idler wheel for this.
To fix mine, i'm just gonna convert to serpentine when(ever) I swap in the new engine.
Old Aug 26, 2002 | 10:21 PM
gmgod's Avatar
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
Axle/Gears: 7.5 / 3.42's
I'd say swapping to serpentine is the only way to cure it for good, though I could get mine tight enough that it woud be OK for a while with a 1/2 inch drive ratchet.
Old Aug 26, 2002 | 11:04 PM
Ray87Z's Avatar
Car: 94 Z28
Engine: LT1 w/ headers, catback, CAI, tune
Axle/Gears: 3.23s
Do you still have the support bar brace things sticking off the A/C compressor bolted on to the block (or was it the exhaust manifold botls, can't remember) to add rigidity? I didn't bother to put that stuff back on when I did headers, and found out the hard way that adds a ****load of noticeable vibration inside the car anytime you turn it on. Bolted those supports (? Think there was more than one, maybe I'm mistaken) back on and it cured it right up. My belt was never visibly wobbling enough to impact anything though, WTF is up with that?
Old Aug 27, 2002 | 05:01 PM
fourspeed's Avatar
does anyone have any machine shop contacts....how about fabricating a pully to ride on the belt between the compressor and water pump pulley? maybe the tensioner pulley could ride on the top of the belt....wouldn't take much
any takers?
Old Aug 27, 2002 | 08:17 PM
Vettetrax's Avatar
Car: Camaro Z28
Transmission: auto
man i dunno but that is annoying i have loud exhaust and when i turn the AC on it sounds like a helicopter under the car or something, it over powers the exhaust on the inside...
"how about fabricating a pully to ride on the belt between the compressor and water pump pulley?" that sounds like a good idea...
Frozer!!!
Jan 19, 2024 04:55 PM
BlueIroc-Z
Jun 9, 2019 03:22 AM
colton_carlson
Mar 8, 2019 12:21 PM
Thaney9
Aug 7, 2015 08:25 PM
