Can someon tell me what this is and what it does?
Old Aug 28, 2002 | 07:47 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
What is the thing in the middle of the pic? I seem to have an intermitant leak of coolant from this thing and I don't even know what this thing is or what purpose it serves me.
The help is appreciated.
Robert
Attached Thumbnails Can someon tell me what this is and what it does?-rmk-mystery-engine-ancillary
Old Aug 28, 2002 | 07:53 PM
89 TA's Avatar
Car: Trans Am/Kenworth
Engine: 383/435 Cat
Transmission: T5/10 speed
That's your heater control valve.
Old Aug 28, 2002 | 08:00 PM
rezinn's Avatar
That sends coolant to your heater core so you can have heat, and that thing you stuck a spark plug in used to be part of your smog equipment
Old Aug 28, 2002 | 08:02 PM
Ukraine Train's Avatar
Car: '87 Camaro LT
Engine: 355 L98
i think it's to keep coolant from going through the heater core when you're heat's not on so you don't get excess heat if your AC is on. i would just get rid of it and run straight hose to the firewall, a lot of cars don't have those and they're fine
Old Aug 29, 2002 | 07:42 AM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Thanks for the replys. The spark plug is in the smog pipe becuas it was sucking fresh air in and messing up my oxygen sensor readings. This was when my MAF was nackered and I needed a quick fix.
KNIGHTE
Southern California Area
Oct 22, 2015 09:11 PM
///DAN///
Sep 25, 2015 02:15 PM
dbrochard
Sep 19, 2015 08:13 PM
83 Crossfire TA
Sep 18, 2015 12:01 PM
89 formula TPI
Sep 7, 2015 11:06 AM
