oil pressure sender replacement
Car: 1988 Iroc-Z
Engine: 5.7 TPI
Transmission: TH-350
Axle/Gears: 12bolt/4:10
Hey guys,
I plan on changing the original oil pressure sender with the autometer oil pressure sender. Will I have to reconnect the factory wire to the sender, because I will be running an autometer electrical oil pressure gauge. Will I have any problems
with any functions of my car?
1988 Iroc-Z
350 tpi
700r-4 with B&M Shift Kit
K&N with ram air
Hooker Super Comp Shortie Headers
Holley AFR
MSD 6AL
1988 Iroc-Z
350 tpi
K&N with ram air
Holley AFR
MSD 6AL
you should have no problems with anything dealing with the running of the car. obviously the dash gauge won't read properly but you will have the new gauge. the only thing the oil pressure sender is hooked to is the gauge or idiot light (if you have one).
Car: 1988 Iroc-Z
Engine: 5.7 TPI
I was reading my manual and it said that the factory wire that connects to the sender activates the fuel pump switch when a certain pressure is acheived. Should I splice the factory wire with the new sender wire to avoid having any problems with the fuel system.
