Engine Oil Priming
Old Aug 31, 2002 | 01:33 PM
DTL504's Avatar
Car: 84 Z28 Convertible 2 Seater
Engine: Dart Little-M SBC 400
Transmission: Pro-built Automatics 700R4
Axle/Gears: Strange Engineering 3:73
Engine Oil Priming
I'm priming my engine with a 3/8in drill and a Summit primer. For some strange reason 15 out of the 16 rocker arms are getting a good flow of oil. The Number 2 Intake is BONE DRY, after about 30 minutes of priming. I took the push rod out and its not clog but have oil on the bottom end and for what I can see there is oil sitting on the lifter, but for some reason its not making it up to the top. Any Idea whats going on or should I just continue to prime and see what happens. I know I should have done this before putting the intake on. My only thought is that I could have a bad lifter. Once again every other rockers has a steady flow of oil.
Thanks for the help in advance...
Old Aug 31, 2002 | 02:04 PM
ede's Avatar
ede
the oil hole in nthe lifter isn't in line with the oil galley to allow oil in it. i wouldn't worry about it and i wouldn't bother trying to prime an engine.
Glowsock
Jul 24, 2025 03:15 PM
Frozer!!!
Jan 19, 2024 04:55 PM
toronto formula
Nov 10, 2015 06:17 AM
Navy8125
Aug 21, 2015 09:32 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
