Need Help About Spark Plugs, And Running Poorly.. Please Read.
Old Sep 1, 2002 | 09:12 PM
Ratstix's Avatar
ok, heres the story.
today i drove about 15 miles away to a friends house. when i got there i turned my car off. went and got here and tried to start my car and all it did was crank. i removed a few plugs to find out they're all fouled (very dry and white) so i guess i'm running lean.
i find somebody near her that has a set of used plugs from his 350 that are in much better shape than mine so he gave those to me. i managed to install 5 of them. then it was a B***h to start my car. but after i finally got it running, if i gave it more than 1/4 throttle it'd bog out and die. so i managed to get home (stopping at o'reileys to get new plugs first) i bought 8 AC delcos and installed 7 of them tonight (broke one) (gonna go to wal mart llater to get one) my car starts right up now. but it still bogs down whenever i give it more than 1/4 - 1/3 throttle. and if i dont llet go of the pedal it'll backfire.
after i put my 7 plugs in i took it for about a 2 mile spin, then iwhen i got back i pulled the #1 plug and it looked as if it'd been running lean. both of my injectors are spraying just fine (TBI) and i can hear my fuel pump running.
the car revs just ine in park or neutral, no bogging at any rpm nomatter how i push the pedal (push fast, slow, relese fast, or slow.)
what could be the cause of this???
BTW (i'm gonna post on the general eninge and TBI boards because i need an answer tonight. this is my only car and i have to be at work tomorrow morning.)
Old Sep 1, 2002 | 10:18 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
hows the fuel pressure? That would be the next thing id check if the plugs are white or the insulation has a melted look to it.
Old Sep 1, 2002 | 11:59 PM
Ratstix's Avatar
i was thinking that, do i have to buy a guage to put on the fuel line to check that?
also i had somebody tell me tonight that it is most defidently the coil. is this possabel?
Old Sep 2, 2002 | 12:26 AM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
Replaced the fuel filter lately?
Old Sep 2, 2002 | 06:39 AM
ede's Avatar
ede
besides replacing plugs have you tried trouble shooting it? got spark to all 8 right? no codes? whats the fuel preasure and volumn? did you check the cat?
Old Sep 2, 2002 | 08:29 AM
Ratstix's Avatar
didn't get any codes. i don't have any cat. i didn't check for a spark on all 8. also the dist. & cap. were replaced a couple months ago.
Old Sep 2, 2002 | 08:30 AM
Ratstix's Avatar
and how do i check the fuel pressure? do i have to get a gauge to put on the fuel line?
and once i get a guage (if thats what i need) what is the correct PSI for it?
Old Sep 2, 2002 | 11:57 AM
Car: 88 Camaro SC
Engine: SFI'd 350
just plumb the gaige into the larger of the two fuel lines (3/8 in one i beleive) in the engine bay. I saw someone who installed the gauge in the rubber line that connects up to the hard lines that run up to the tb. Im thinking of doing the same myself. The normal pressure ramge is 9-13 psi.
Old Sep 2, 2002 | 12:10 PM
ede's Avatar
ede
auto zone has a gauge for tbi trouble shooting for around 40 dollars
Old Sep 2, 2002 | 08:46 PM
Ratstix's Avatar
k. this is bad. went to autozone tonight. they tested my coil and said it was fine.
car fires up fine now that i got the plugs in. but whenever i give it gas (when in gear) it will try to die.
Old Sep 2, 2002 | 09:10 PM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
Rastix,
This is one of the best suggestions....yet you seem to have ignored it.........
Pull the filter off, clean the INLET side and try to blow through it with your mouth. There should be little resistance.
Old Sep 2, 2002 | 10:12 PM
Ratstix's Avatar
k, i will do that tomorrow. as a matter of fact i'll just replace the filter.
i also am going to check my timing, perhaps thats off.
i forgot to mention in the first post that before i drove to the friends house that was 15 miles away i was just above E and i put 7 gallons in. so i'm hoping that it's just the gas.
the knock in my cylinders seems to be getting worse.
Old Sep 2, 2002 | 10:35 PM
Ratstix's Avatar
ok, now whenever i try to start the car it wont start and it backfires as i'm cranking it. when i had it running earlier somebody said it smelled rich.
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
apo_bailon15
Mar 28, 2016 05:20 AM
db057
Aug 22, 2015 08:17 PM
