wut is diff. between.. flexplate, pressure plate, and flywheel
ok.. the pressure plate/flexplate bolt up to the flywheel correct?? so wut is the different between pressure plate and flexplate? is pressure plate for manual trannys with a cluth and flexplate for autos??
one more question.. im upgrading from an auto to a t-56.. so i will need a new flywheel(?) pressure plate and clutch.. do i have to buy these all seperatly?? i went to thunder racing. and im not sure if i need all three of these for the swap, or the the flywheel will come with the pressure plate or what.. im confused!!!
37-261871 McLeod Performance Clutch Disk, Shifts to 7500 RPM, 1993-1997 LT1 F-Body
$133.33
37-360822 McLeod Pressure Plate including Throw-Out Bearing, 1993-1997 LT1 F-body
$293.33
37-460350 McLeod Steel Flywheel, 25# [Ring Gear OD=13.835, Ring Gear Teeth: 153, Clutch Patterns: 4]; 1993-1997 LT1 F-body $360
$133.33
$293.33
A flywheel is the term used on a manual car, a flexplate is on an automatic. Pressure plate and flex plate are completely different terms. The pressure plate is connected to the transmission, the flywheel is connected to the engine. Sometimes flywheel and flexplate are used interchangably, although it's incorrect to do so. If you haven't already, look into an aftermarket t56. It costs more but is made to bolt directly into your car with little modification. I'm sorry, I don't have the link here because I'm not at home. I'm sure someone else does, though.
Car: 1989 IROC-Z
Fronzizzle
Mar 18, 2019 08:29 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
BlackphantomZ28
Apr 24, 2016 08:14 AM
someone972
Aug 30, 2015 12:52 AM
