Damper removal/installation
Old Sep 4, 2002 | 01:59 PM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
Ok...time to replace the damper.........
My engine shop is 550 km away from me, and my damper cuts into my oil lines so I wont be able to drive the car to him....
Do I need any special tools to do this?
anything else to thing off?
Thanks....................
Old Sep 4, 2002 | 02:16 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
You'll need a harmonic balancer puller. Autozone allows you to check them out.
But I guess there are no Autozone's in Sweden?
Old Sep 4, 2002 | 03:14 PM
ede's Avatar
ede
you'd need a puller to remove it and an installer to put it back on
Old Sep 4, 2002 | 04:58 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Don't ever use the center crank bolt to pull the balancer back onto the crank... you'll hear a "snap", and you'll be screwed. You can make a balancer installation tool for cheap using threaded rod.
MoJoe
Sep 15, 2015 12:50 AM
jimmy_mac
Sep 6, 2002 08:27 AM
Bunker82
Jun 30, 2002 01:36 AM
P J Moran
Apr 17, 2001 09:44 AM
Nitro Don
Mar 17, 2001 10:27 PM
