serpentine craziness
Old Sep 6, 2002 | 06:51 PM
feelthedrama420's Avatar
will a serpentine setup from a 90 full size blazer fit right on an 88 formula
:hail:
Old Sep 6, 2002 | 07:46 PM
Hulk0202's Avatar
I belive al the accesory holes should be in the same place so everything should bolt up. Now there may be some clearance issues, that youd probably have to size up yourself. The only thing I can think of that may cause a problem is the ac compressor.
Old Sep 7, 2002 | 02:06 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
It will all bolt up, but I believe the A/C compressor and alternator are too high up to clear the hood. My 94 suburban (TBI 350) has the alternator and A/C compressor mounted about 2" higher than the ones on my car. Look in local junkyards, serpentine F-Bodies are not too hard to find around here. I found an 89 RS with all the serpentine accessories and pulled the whole setup.
Pac J
May 17, 2020 10:44 AM
jrdturbo
Mar 31, 2016 02:58 PM
Rocket-Doc
Nov 14, 2015 02:08 PM
SRKLEGIN
Sep 30, 2015 07:19 PM
Zell1luk
Sep 29, 2015 10:36 AM
