Car won't start. Help!
Old Sep 6, 2002 | 09:04 PM
84 Challenge's Avatar
My 84 Iron Duke won't start. So far, I've replaced the fuel pump, relay, fuse. Still nothing! No infamous fuel pump hummmm. I'm now taking suggestions. One thing I'm a little concerned about though is the pump installation. It had an AC pump & replaced with a aftermarket unit. The AC had some sort of plug for connection. The aftermarket has screw type connectors. The + wire really doesn't go anywhere. It went to some tube looking thing. Does that sound familiar? This is really pissing me off! Any suggestions?
Brandon
Old Sep 6, 2002 | 09:16 PM
87Formula4bbl's Avatar
Car: '87 Formula
Unless you are sure that it is a fuel problem, you might want to check the electrical system. You can either take the wire connecting the coil to the distributor off and use a spark plus and see if it makes any spark or you can try a few random cylinders, by the same means.
Possible other fuel problems:
Bad gas possibly??
Carbuerator plugged or has build-up inside??
Old Sep 6, 2002 | 09:53 PM
Not sure of anything right now. If I can't figure this our quick, the car will be in storage till a V-8 can be had. Thinking about saying "f*ck it" and put it up on jack stands and dismantle the 4-cyl related parts.
Brandon
theshackle
Mar 5, 2017 06:37 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
justin57
Aug 20, 2015 07:05 PM
ZsTransAm
Aug 11, 2015 07:30 PM
86Base
Aug 8, 2015 01:34 PM
