New Motor, doesn't start good, idles bad.
Old Sep 9, 2002 | 05:20 PM
madmanups's Avatar
I just put in 350 TPI w/ vortec heads. The car won't start on first try. Well actually sometimes it does but rarely. It also idles bad. Sometimes it idles level then suddenly it shotts up a hundred rpm. It's like its coughing or something. I think it might need a fuel pump because that is the only part of the rebuilding process that we did not replace. I heard that I need to gap my spark plugs higher because my new motor is so much more powerful. Is this true? Please help me.
Old Sep 9, 2002 | 07:29 PM
Hellraiser's Avatar
Re: New Motor, doesn't start good, idles bad.
I think i would double check the timing at TDC (with a timing light), and look for vacuum leaks. Then maybe if the issue isnt resolved reset the Idle Air Control motor (follow the instruction in the tech article section).
Hellraiser
Old Sep 9, 2002 | 07:36 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Make sure your wires aren't crossed. I know I crossed mine once and it ran like crap, backfiring every few seconds.
Old Sep 9, 2002 | 08:53 PM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
vortec heads + non vortec tpi base = port alignment problems????
are you using a vortec tpi base? correct me if i'm wrong here guys.
specialized
Jun 18, 2022 09:26 AM
Wade787b
Sep 29, 2015 01:15 PM
db057
Aug 22, 2015 08:17 PM
mizz0313
Aug 12, 2015 06:45 AM
killer777
Aug 8, 2015 02:47 PM
