Pulley install
Car: '99 Cobra
Engine: 4.6 DOHC 32V
Transmission: T-45
Axle/Gears: 4.10
Pulley install
This is kinda a dumb question, but when I got to remove the 3 bolts on the crank pulley, it won't move or mess up my timing will it?
Thanks a lot in advance!
Car: '94 Corvette
You kind of on the LT1's, which is a balancer/pulley deal plus has screw in weights & no keyway. It doesn't accualy change the timing, but will screw the balance up a little.
So your question isn't dumb at all.
The only way to move the timing is by messing with the chain, or distributor. Hardware wise ...
Ron
Ron
evilstuie
Jan 9, 2020 08:29 PM
evilstuie
Apr 14, 2016 08:52 PM
Navy8125
Aug 22, 2015 07:13 PM
Street Lethal
Aug 12, 2015 11:33 AM
