speedo demons
Old Sep 14, 2002 | 12:35 AM
92rsv8's Avatar
Car: 1992 camaro rs 97 yoyota camry
Engine: lo3 carbed
Transmission: t 5
speedo demons
hello i am new to this forum and i would like to ask if anyone has any info on how to fix my speedo:
when i am in fith gear and i hit the gas it drops to zero... also i think it may be a little off i am not sure though??? it seems to work fine in the other 4 gears. if any one can help i would much apreciate it.
chris
Old Sep 14, 2002 | 07:28 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
My car used to do that...
Go to the dealer and get the speedo driven gear housing, and a new gear to match whatever you have. The OE chinesium housing is letting the gear move away from the drive gear, because of wear; the reason it does it in 5th is that in that gear, the mainshaft (where the drive gear is located) is forced slightly away from the driven gear, too. The new housing is steel, a far superior piece to the crap they put in on the assembly line.
Old Sep 15, 2002 | 11:24 AM
Vader's Avatar
Originally posted by RB83L69
..chinesium...
Wow, I haven't heard about that one in a while. That stuff is now almost as rare as unobtanium...
And to further complicate the matter, wouldn't Rob Zombie classify that as a "Demon Speedo"?
Also, I could be mistaken even more, but doesn't a '92 have the VSS at the trans, which means the VSS housing itself is used to retain the driven gear?
GTAman
Jul 3, 2024 07:29 PM
Elephantismo
Feb 13, 2019 12:51 AM
Nervous2
Oct 8, 2015 10:53 PM
rs_z28_vert
Sep 30, 2015 09:47 PM
TrevinE
Sep 14, 2015 03:20 PM
