SES Light Trouble
Old Sep 14, 2002 | 02:09 AM
RGVMike's Avatar
SES Light Trouble
i got a question, i recently had my service engine soon light come on and i tried doing a self diagnostic with the paper clip and it will not flash the codes. a while back it worked and i found my o2 sensor was bad. well now as i turn the key to run the SES light comes on and doesnt flash at all, not even the first 12 code. any ideas on what could be the problem? did i ruin the harness maybe? thanks- 91z28
Old Sep 14, 2002 | 07:20 AM
ede's Avatar
ede
if you have no coeds stored and you jump the ALDL you'll get a code 12 showing the ecm is working properly. no code 12 indicates a problem with the ecm, or maybe a wireing problem between the ALDL and the ecm, or ground.
Old Sep 14, 2002 | 11:30 AM
RGVMike's Avatar
thanks for replying, i appreciate any help i can get. -mike
Old Sep 14, 2002 | 02:35 PM
camaro89rs355's Avatar
Car: 89 Camaro RS
Engine: 355 TBI
IT BE BETTER IF YOU JUST WENT TWO THE GM DEALER AND BOUGHT A REAL CODE KEY UNSTED OF THE PAPER CLIP. THAT WAY YOU CAN BE SURE THAT THE COMPUTER IS WORKING OR NOT. THE KEY IS ONLY TWO DOLLARS.
eightsixseven
Dec 16, 2024 01:50 PM
Toolsin
Feb 2, 2016 06:55 AM
fasteddi
Sep 10, 2015 09:32 AM
Omega
Aug 10, 2015 12:46 PM
