Please help me
Old Sep 14, 2002 | 06:43 PM
j_bonham69's Avatar
Please help me
ok I have an 89 TPI 305 Trans am. last week my car died on me. it wouldent start so i sprayed some carb cleaner into the throttle body and then it started. i figured it was the fuel pump. i changed it and tried to start it and again it didn,t start. do i have to prime the pump or anything? if not what else could it be. it still starts on carb cleaner.
Old Sep 14, 2002 | 06:54 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Did you change the fuel filter too?
Old Sep 14, 2002 | 07:26 PM
j_bonham69's Avatar
no but it wasn't clogged i checked
Old Sep 14, 2002 | 08:01 PM
laiky's Avatar
did you check for power at the fuel pump? do you hear it when you cycle the key, yes it does have to be primed but 15 or so seconds of cranking will do this. Did you check the inertia switch? fuel pump relay? DO you have fuel pressure.
These are the first things to try, if it fires on carb cleaner then you have everthing else but fuel.
