Afr's And Different Spark Plugs???
Car: 1991 FORMULA
Engine: ZZ4 + LT4 HT CAM 430HP
Transmission: 700-R4 COMING T56
Axle/Gears: 9" 4.56's (COMING)
i'm now in the process of choosing the spark plugs for my new afr 190's and figure i would ask what types of experiences you all have had with your afr's......
they reccomend acfr3ls but i would like to get some bosch platinums or eqevilent.....
what types of probs, or luck have you had with your selections???
thanks... badgta
thanks... badgta
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
I run the AC's they recommend.I can't run any platinum's because of my addiction to the bottle.I run AC fr5ls on the street,then when I am going to the strip(which has been a while) I run 2 heat ranges colder.
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
Hey Mkos1980..what made you run the FR5LS?I went to them due to the FR3LS seemed to be way to cold of a plug for my motor on the street.Just curious to see why you are running them.TIA
Car: 1991 FORMULA
hey
the reason i asked is because i had bought brand new bosch platinums for my stock l98, and i never put them in....
when i tired to use em on my afrs, they didn't even go all the way into the combustion chamber!!!!
there afr 190's w 68cc chambers and l98 plug angle....
are there any real short header type plug like they reccomend that will fit the afr's???
i will be running hedman long tubes and need clearence!!!
any suggestions????
any suggestions????
86CamaroDan
Sep 29, 2015 10:08 PM
