Holley Street Dominator Fit
Old Sep 15, 2002 | 03:28 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Does anybody know if the Holley Street Dominator will fit under the "composite" hood of an 82 CFI, or camaros in general. The PART # 300-36 and the height is 4.44" in the front and 5.33" in the rear.
Leigh
Old Sep 16, 2002 | 12:29 AM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
Does anybody have a clue? It is a little taller than the weiand stealth.
Old Sep 16, 2002 | 01:12 AM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
This one is going to be real close.
While simular in height to the Performer RPM, The holley 300-36 it is about .4" higher at the front of the carb (or aircleaner)
To fit this intake under your stock hood:
You are going to have to use a drop base air cleaner
The lowest one is the one used By GM on late 60's
muscle cars see my pick.
It will be a good 1/2 inch lower and better designed than any of the copy cat aftermarket ones. See the pics.
The aircleaner lids seem to be the same, its the base that is different. You'll be limited to a 14x2.5" filter element.
Reguardless of what Experts will tell you, this is all the filter height youwill need for up to 450/500hp IF YOU USE THE RIGHT GM AIRCLEANER BASE. There is a difference.
You can still buy this base from Aftermarket restoration sources
like YEAR ONE and Eckler's Corvette. See this thread:
https://www.thirdgen.org/techbb2/sho...AND+aircleaner
I have not actually fit this exact manifold to a third gen, but if any
set up is going to work, its this one. It is going to be close.
Further:
Best to use a **Holley** carb on this one.
An Edelbrock carb requires an Edelbrock# plastic adapter spacer
to use this GM aircleaner base. It's about 3/8".
That will raise the whole aircleaner assembly an additional 3/8"
Because of this I'm pretty sure The edelbrock carb/ holley 300-36
combo will not fit under the stock hood.
Old Sep 16, 2002 | 01:20 AM
F-BIRD'88's Avatar
Here is a pic of the "Z28","L-88", "LT-1" " L-72" aircleaner base.
Frozer!!!
Jan 19, 2024 04:55 PM
Street Lethal
Apr 30, 2019 12:14 PM
9192camaro
16
Feb 3, 2019 12:21 AM
BlackphantomZ28
Aug 22, 2015 01:00 PM
theurge
Aug 21, 2015 12:46 PM
