Vats code...
Old Sep 18, 2002 | 12:58 PM
91-GasGuzlinZ-28's Avatar
Vats code...
Whats the code for VATS?
Old Sep 18, 2002 | 03:51 PM
Vader's Avatar
Code for VATS? Do you mean a VATS error code? That would be a 46, 53, or 58 (and a 56 on Cadillacs, just in case).
If you want a fairly complete list, check this link: GM RPO Codes 1992.pdf
You'll need Adobe Acrobat reader to access the file.
Old Sep 19, 2002 | 05:27 AM
kat3876's Avatar
your vats is tied in with the starter so i would suspect you have a loose or broken wire from when you installed headers or other work around that area as it happened to me wich left me dumbfounded for a week of sometimes starting sometimes not with it setting the code only sometimes,, also ran across the situation of the key wearing out with the chip in it witch is happening more frequently as these cars age,,don
RS Reaper
Oct 17, 2018 07:52 PM
djmarch
May 8, 2016 11:32 AM
AmorgetRS
Sep 28, 2015 09:33 PM
Winchester1094
Sep 15, 2015 09:48 AM
3rdgenkindagal
Sep 13, 2015 02:02 PM
