Fuel Delivery Question??
Old Sep 18, 2002 | 01:39 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I was just reading a website, when I do finally get some heads, I'll be pushing around 350-385hp hopefully.
Now, we'll I need a new fuel pump, I'm running the stock LG4 right now. When I got the 350 I had bought a pump, but it wouldn't fit between the block and the frame or something like that.
Old Sep 19, 2002 | 09:31 AM
Vader's Avatar
One word: electric
Old Sep 19, 2002 | 09:47 AM
Car: 99 Formula
Axle/Gears: 342
Originally posted by Vader
One word: electric
one word, maybe more. Would that have to be in the tank?
Old Sep 19, 2002 | 10:56 AM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
The Carter aka Federal Mogul hi flow mechanical fuel pumps
with the rotateable bottom housing will fit your F- Body
You can buy them with various fitting size
inlets and outlets, which you can position to best fit your car.
you would want to have a minimum 3/8" fuel line
from the tank to the carb to ensure enough fuel flow.
The pump I have puts out 9psi at idle.
A edelbrock carb only likes about 6psi so ya need to use a regulator. (Holley)
As long as your present pump can maintain
3 to 4psi thru a 3/8" line at WOT at high rpm in hi- gear (like at the finish line)
it is feeding your motor enough fuel.
Old Sep 19, 2002 | 08:03 PM
89Irocz23's Avatar
it doesnt have ot be in the tank. you can just put a inline one inbetween 2 fuel lines.
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
Vintageracer
Jan 10, 2020 05:33 PM
Infested
May 22, 2018 11:56 PM
redmaroz
Aug 16, 2015 11:40 PM
