Tall deck block, Do standard heads work?
I am wondering if you have to mod the heads and intake to use a tall deck block 9.525" vs the standard deck of 9.025"?
Seems to me this would create a small gap?
Or would everything work just fine?
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Heads are not the problem.
.400" longer pushrods. Since you shouldn't be using the tall deck truck pistons (extra compression ring), you need .400" longer con rods to use automotive pistons.
Tall deck intake manifolds are available but there are spacer plates available to use a short deck intake manifold. The distributor will also sit higher.
If used in a third gen, exhaust could be a problem since the exhaust ports will also be taller and the most common header used is Hooker Supercomps. They're a tight fit on a shortdeck block.
9192camaro
16
Feb 3, 2019 12:21 AM
NinjaNife
Aug 23, 2015 11:49 AM
rithsleeper
Aug 11, 2015 07:55 AM
