Question for those who have vortec heads
Car: Z28
I was going to put the coil, and egr solnoid on my engine today using the stock braket that uses the bolts on the intake. Being that the bolts are at a different angle and farther apart they won't work. Also I'm using a v-belt setup and one of the brakets uses the front two drivers side intake bolts, but the braket dosn't work because of the two things I mentioned before.
What did you guys do to get this to work?
I ditched the stuff that didn't want to work. AC isn't important to me, so I left the compressor hanging loose on it's bracket. Some people may think I'm crazy, but if you make sure it's secure and not going to move and interfere with any other parts and can live without AC or a good defroster, leave it unhooked. That's the only thing I had a problem with. Hope it helps you a little.
84z96L31vortec
Aug 20, 2017 12:16 AM
L98GTA87
Aug 11, 2015 06:55 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
