Screw in rocker studs
Old Sep 22, 2002 | 09:39 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
How do i know if i have screw in rocker studs, what do they look like? I have 3998993 heads with 1.94" intake on a 3970010 350.
Old Sep 22, 2002 | 09:45 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
There are 2 types... the performance type has a hex head to install it, that also holds the guide plates. The stock repair type for a pulled out pull-out stud is just a stud, with no hex; you use 2 nuts to put it in.
Los "Hecho En Mexico" 993s don't come with screw-ins, they have the pull-out kind. They also come from the factory with regular 1.94" intake valves, as do the vast majority of 350 heads.
Old Sep 22, 2002 | 09:50 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
There are not made in mexico 993 they are from 73. They definitly don't have a hex head. So what do the pressed in studs look like.
Old Sep 23, 2002 | 08:42 AM
Vader's Avatar
The pull-out studs (or as you call them, pressed-in) have a straight body all the way into the head. The "replacement" type screwed studs come in two flavors - one with a hex collar and one with a swaged (bulged) collar).
The hex collar versus the pull-outs:
The hex and swaged collar type:
Old Sep 23, 2002 | 12:30 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
Ok thanks i guess i have pressed "pull-out" studs.
RedLeader289
May 28, 2019 01:47 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
Bigold4x4
Sep 28, 2015 05:21 PM
