wells MAF question
Old Sep 23, 2002 | 03:05 PM
L98FORM89's Avatar
Car: 1989 Formula 350
Engine: 355 HSR
Transmission: Rossler 700R4
Axle/Gears: 9 bolt/3.27
wells MAF question
I bought a new Wells MAF to replace my Bosch(I stuck my finger through one of the wires, I know ,I know).But after installing the Wells my car has a stumble off idle that it didn't have before. The Wells unit is different inside in that it has a circuit board and a piece of foil inside instead of the wires and heat sinks that are in the Bosch.Is the Wells compatible with my set-up. thanks Stewart
Old Sep 23, 2002 | 03:41 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
If it's the SU 145 then it's compatible. The wells is designed to use the more reliable circuit-board style electronics like the LT1 MAF uses, but with an output that's compatible with our computers. I'm running one on my GTA and it works beautifully.
Old Sep 24, 2002 | 12:25 AM
L98FORM89's Avatar
Engine: 355 HSR
SiCkRs
Members Camaros
32
Jul 1, 2018 04:53 AM
maroe624
Apr 16, 2017 08:29 AM
ziggy89
Exterior Parts Wanted
Sep 10, 2015 08:44 AM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
