Heat shield for starter
Old Sep 10, 2002 | 07:31 PM
Harley61's Avatar
Car: 90 RS / 89 IROC
Engine: 305 TBI / 305 TPI
Transmission: 700R4 / T5
Axle/Gears: 3.73 / 3.08
1990 RS 305 Camaro...
Has anyone used the blanket type heat shield on your car? How was the fit? Any problems with it? Did it solve the heat soak problem?
Would a mini starter fix the problem of heat soak better than putting a blanket on the full size starter?
Any other suggestions are welcome.
Thanks guys!
Old Sep 13, 2002 | 02:41 PM
Harley61's Avatar
Old Sep 13, 2002 | 02:58 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The stock starter is a POS. You wouldn't believe how bad it actually is until you try a mini.
I was out in Burbank and Hollywood the other day... flew into and out of Burbank. I used to live in north SD county around Carlsbad, it was good to be back.
Old Sep 13, 2002 | 03:53 PM
Harley61's Avatar
I hope you enjoyed your stay. I'm about 3 minutes from the Burbank airport...
So a mini starter sounds like the way to go. I will be looking into that. Thanks for the info.
Old Sep 13, 2002 | 04:00 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
It was just work... I'm doing a project with a radio station, to build studios to move them from Sunset Blvd. to a bldg in Burbank. I was there the night of the Hollywood Bowl, what a hassle the traffic was that night. Other than that, it was great.
I have a CVR mini-starter that I got for my 400 when it was in my 83; the weenie stock thing could barely turn that motor over at all, but the CVR spins it like it's not even there... amazing difference. I was not prepared for the degree of improvement it made.
Old Sep 13, 2002 | 04:21 PM
Harley61's Avatar
And no probs with heat? Did you have any probs with the heat before you changed it?
Old Sep 13, 2002 | 06:27 PM
88Bravo's Avatar
Car: 1988 Pontiac Firebird, flat black
Engine: Stock 305 LO3
Transmission: Five speed
I have the hooker super comp shorties, and the big stock replacment starter. I installed a starter wrap, and then put a peice of wire around it because I didn't like the way the velcro looked. I wanted to make sure it stayed on. I have had no problems with it.
Old Sep 13, 2002 | 07:38 PM
Harley61's Avatar
Any pics of the job? I am STILL having probs even with the blanket on the starter. (although the problem is not as bad)
Old Sep 13, 2002 | 07:56 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
No, I never had any particular problems with heat, except that when the motor was warmed up it would try to fire on the first cylinder as the starter tried to turn it over, at which point the cylinder pressure would almost turn the motor backwards.... but with this starter, it doesn't matter whether it's hot or cold, it turns the motor fast.
Old Sep 13, 2002 | 08:29 PM
Harley61's Avatar
Ok, im set on getting one now. Now what one do you guys recomend? Any better than the other...etc?
Old Sep 24, 2002 | 02:30 AM
Harley61's Avatar
ttt
3rd gen money
Oct 11, 2019 09:57 PM
sheachopper
Jul 31, 2019 11:27 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
