What is causing this noise??
Old Sep 24, 2002 | 10:02 AM
hellfire's Avatar
Car: 91 Firebird
Engine: 305 tbi
Transmission: manual
I have a '91 305 tbi 5 spd. when I take off I hear a gurgling or knocking sound when ever I am accelerating. I can put the car in neutran and rev it and no noise but whenever I'm in gear and accelerating it makes this sound and its getting worse. It sounds like its coming from the engine bay. Anyone have any idea what it could be? I have a fear that this is going to cause some serious trouble if I dont get it fixed soon.
Old Sep 24, 2002 | 11:20 AM
Vader's Avatar
Does the pitch of the sound vary with engine RPM or road speed? One would indicate an engine/clutch/input shaft problem, while the other would indicate a transmission or driveline problem.
Old Sep 24, 2002 | 12:14 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Exhaust leak?
Old Sep 24, 2002 | 12:52 PM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
sounds like pinging to me. check your ignition timing first. then check/replace knock sensor. try checking the timing first and report back with results.
Old Sep 24, 2002 | 12:57 PM
hellfire's Avatar
Car: 91 Firebird
Engine: 305 tbi
Ill go with the ignition check. just replaced clutch pilot and throwout bearing. the noize was there before i did that. I thought my cat was going out but the noise seems to come from the engine area. same sound at all speeds just a little louder with more pedal.
Old Sep 25, 2002 | 07:30 AM
SgtSkip's Avatar
I just has something similar and it turned out that my Cat bolts were working loose.
HoosierinWA
Oct 7, 2015 10:15 AM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
sjorgens
Oct 1, 2015 07:54 PM
thejimsterz28
Sep 30, 2015 08:52 PM
