Smoke at startup
Old Sep 24, 2002 | 11:04 PM
californiaZ's Avatar
Smoke at startup
Okay, here it is. White smoke, only at startup after the car has sat for a while. Smells kinda like burnt electronics, not like oil or antifreeze. I know it sounds kinda wierd. My theory is the head gasket. Any thoughts?
Old Sep 24, 2002 | 11:31 PM
curt86iroc's Avatar
Car: 1990 IROC
Transmission: TH700-R4
yeah, white smoke is usually antifreeze which usually means head gasket...
Old Sep 25, 2002 | 02:00 AM
rezinn's Avatar
Check if you're missing coolant and pressure test the system. That will at least tell you if you're losing coolant and maybe where. Could be an intake leak as well, or something cracked.
FormulasOnly
Jul 23, 2018 08:47 AM
86White_T/A305
Mar 6, 2016 01:48 PM
Badass355ciz28
Sep 28, 2015 08:31 PM
KCG
Sep 23, 2015 09:05 AM
Accerrito22
Sep 5, 2015 09:34 PM
