Dynamic compression ratio to great
Old Sep 26, 2002 | 11:00 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
I was thinking of getting some Dart Iron Eagle 200's with 64cc chambers and using a XE268 on my 0.04 over 350. I have four valve reliefs per piston. Will the dynamic cranking compression ratio for this setup be too great for pump gas on the street. Is this cam the best choice? What would be a better cam?
Old Sep 27, 2002 | 04:28 AM
ede's Avatar
ede
what pistons? flat tops or dished? at any rate i'd guess you'd be fine but there is a lot of varances even with the same compression ratios depending on piston design among other things.
Old Sep 27, 2002 | 04:37 AM
ronterry's Avatar
Car: '94 Corvette
With 4 reliefs I would assume flattops...I would guess 9.5-10.0:1
I've seen production Vette's with 10.8:1, but you'll need the good stuff.
My '94 is about 10.5:1, and requires (well tells you) to run premium.
Ron
Old Sep 27, 2002 | 01:03 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
Yes they are flat-tops with 4 valve reliefs. What is the average piston in the hole distance?
Old Sep 27, 2002 | 01:31 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Piston to deck height is usually .025 to .045" on a undecked block
with typical factory and replacement "flat tops"
The only way to tell is to actually measure your assembled short block. You can juggle the final cr with different thickness head gaskets.
At any rate your dynamic cr and mechanical cr will not be exessive with 64 cc heads.
beastin91rs
Oct 9, 2015 07:38 AM
camaroinmotion
Exterior Parts for Sale
Sep 2, 2015 08:25 AM
gixxer92
Sep 1, 2015 04:32 PM
NinjaNife
Aug 23, 2015 11:49 AM
86IROC112
Aug 21, 2015 07:20 PM
