Mechanical fuel pump, swap to 255lph intank
Car: 1986 Z28 / 2012 CLS550
Engine: F-1R -> Aluminum block 540
Transmission: T56 Magnum + GForce gears
Axle/Gears: Ford 9" 3.00's + Eaton Truetrac
I am looking at my manual here, for my '86 Z28. Right now I'm using a mechanical pump (carb setup) but I'm building a fuel injection setup. The manifold is done, and the electronics are on the way. I bought a 255lph *intank* fuel pump because I want to run an intank pump.
I'm wondering if anyone knows what I'll have to do to hang this pump in my tank, where before I only had a pickup. It looks to me like the tank sender assembly, which is where the lines come out of the tank, are responsible for holding the pump.
I'm not worried about dropping the tank, so please don't suggest an external pump
Thanks,
Thanks,
...don't suggest an external pump.
BTW, electronics are in
Hit the junkyard and grab the in-tank pickup assembly, it will come with the mounts and wiring for the pump. I bought mine from Knox Auto Parts in Knoxville, TN (www.knoxauto.com) and Camaro Heaven (www.camaroheaven.com) sells them also.
I agree with you on sticking with in-tank pumps, did the same thing when I switched from TBI to TPI.
Perfect, thats exactly what I was looking for!
theshackle
Mar 5, 2017 06:37 PM
R3500
Aug 17, 2015 12:16 PM
