spark plug wires
Old Sep 30, 2002 | 10:44 PM
BigMike1610's Avatar
Engine: 305 tbi=LO3
Transmission: Automatic
spark plug wires
i might need to get new spark plug wires on my t/a, when i changed the rotar and cap, i noticed some corrosion on the connectors in the wire. does getting a larger gauge wire help? or should i get the same size thats on the car already?
Old Oct 1, 2002 | 10:13 AM
Sciguyjim's Avatar
Getting a different gauge wire will have no effect on how much corrosion builds up over time inside the connectors. Just replace the corroded wires with new ones, make sure they snap into place securely, and keep them dry inside.
Old Oct 1, 2002 | 12:07 PM
92RSFivePointSlow's Avatar
Car: 2002 Harley Nightrain
Engine: twin cam 88ci
Transmission: manual
usually the "gauge" of spark plug wires only has to do with how much silicone is around the little tiny core. That wont help your problem though. Make sureyou use di-electric grease on the terminals.
Old Oct 1, 2002 | 10:07 PM
Engine: 305 tbi=LO3
no, i meant will a wire with a larger diameter help my engine at all
Old Oct 1, 2002 | 10:10 PM
robbob's Avatar
Anything more than 8mm is overkill in a typical street car.
Old Oct 1, 2002 | 11:05 PM
trans87's Avatar
Car: 2006 Tacoma X-Runner
Engine: 4.0L DOHC V6
Transmission: 6-Speed Manual
Axle/Gears: 3:15 LSD
Around 8 or 8.5 mm will give you optimum spark and give nice insulation for the wires. I am using Jacob's Electronics 8.5mm wires on my car. The ones on before were 7mm
Old Oct 1, 2002 | 11:38 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I'd go for 8.5 or 8.8 mm if you can, just a little extra protection, specially for header applications.
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
g.l.mos
Aug 22, 2015 12:02 AM
Bryan F
Aug 18, 2015 02:28 PM
