Car sometimes stalls on starting; RPM fluctuating at idle
Old Oct 1, 2002 | 08:31 PM
blue86iroc's Avatar
Car: 1986 IROC-Z
Lately, I've noticed that the tach on my '86 IROC tends to fluctuate around idle. In addition, the car has been difficult to start lately (sometimes stalling right after it starts). I'm not tripping any codes, but I did install a new tranny two weeks ago... I didn't seem to notice this until just a few days ago. My car idles around 500 RPM. I have a Pro-Built TH-700 with a 2,400 RPM torque converter. I really haven't noticed any difference in performance, but that could be because I'm benefiting from the new transmission. After about 2,500 RPM, the fluctuation seems to go away. Any ideas?
EDIT: I forgot to mention that it smells like fuel every time I start up my car... like really strong.
Old Oct 1, 2002 | 09:31 PM
Vader's Avatar
First, the idle RPM is too low. A sluggish IAC can cause your symptoms. Try cleaning the TB and IAC, adjusting minimum air, and setting the TPS. Check this thread for details: https://www.thirdgen.org/techbb2/sho...hreadid=134125
Old Oct 2, 2002 | 07:00 AM
blue86iroc's Avatar
Car: 1986 IROC-Z
Thanks Vader! I'll be sure to try what you suggested.
Old Oct 2, 2002 | 08:32 AM
Vader's Avatar
Once you solve the idle issues, the fuel odor on startup may or may not be solved. If not, start by checking the cold start fuel line and injector.
Old Oct 2, 2002 | 09:22 AM
plohound's Avatar
Hey Vader you seem very kind and knowledgeable.
Question, got an 84 305. My acceleration sucks! just got a rebuilt carburator, new plugs, wires, cap and rotor. I thought this would solve my problem , but it didn't. Any suggestions?
Thank you!
specialized
Jun 18, 2022 09:26 AM
Wade787b
Sep 29, 2015 01:15 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
killer777
Aug 8, 2015 02:47 PM
