signs of bad rings
Old Oct 1, 2002 | 09:53 PM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
signs of bad rings
ok, i pulled the heads off the 350 tonite........i have a set of barely used 305 heads i am putting on it, so lets not worrry about valve seals
except for the usually carbon buildup on the tops of the slugs, everything looks pretty clean
would it look any different if the rings were causing oil to be burned?
theres a slight ridge at the top of the bore......not too concerned with that as its slight...........
comments? what should i look for before i install the engine?
thanx
Old Oct 2, 2002 | 12:17 AM
Kevin Johnson's Avatar
You might seriously consider installing a fresh set of rings just for insurance. You have most of the work done right now.
If you have a perceptible ridge in the bore that means your rings are worn too.
Old Oct 2, 2002 | 05:38 AM
yeah, i guess that wouldnt be a bad idea...........the pistons that i currently have are garbage for performance too, so i guess i should do new pistons and rings
i guess while i have it all apart, might as well check the bearings too
thanx
Old Oct 2, 2002 | 11:37 AM
so before i put the new pistons and rings in, i need to ream to ridge too, huh?
Old Oct 2, 2002 | 12:28 PM
Yes, but be carefull not to remove too much material.
F-body driver
Mar 6, 2023 11:44 AM
64Chief
Sep 12, 2015 08:05 AM
DARKmj16
Sep 9, 2015 04:07 PM
BOOT77
Sep 5, 2015 03:55 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
