bad fuel pump?
Old Oct 3, 2002 | 07:54 PM
tzweelz's Avatar
bad fuel pump?
car is an 89 305tbi
after i filled up at the gas station, it would not start. i noticed no fuel going to the TBI. and i could hear no sound coming from the fuel pump when i turn the key.
after a few hours it starts up and i drive it home just fine.
next day, i start it and it sputters badly, but is fine at higher rpms.
few hours later nothing again.-no sound at all from fuel pump, and nothing coming out of TBI.
i dont like this motor and do not want to put any significant money into this stock 305.
does this sound like bad fuel pump, or could it be something electrical?
also, would a stock fuel pump be enough for an LT1s fuel needs?
Old Oct 3, 2002 | 08:41 PM
trans87's Avatar
Car: 2006 Tacoma X-Runner
Engine: 4.0L DOHC V6
Transmission: 6-Speed Manual
Axle/Gears: 3:15 LSD
Make sure to check your fuel pump fuse and relay. Sounds like the fuel pump going to me. My car does the same thing. I would try to start and it and it would start then die. If I gave it gas it would run but as soon I let off the car would die. The fuel pump is making a jingling noise on my car as well which lets me know its going.
Old Oct 3, 2002 | 10:19 PM
tzweelz's Avatar
all the fuses at the fuse block are OK. ill have to look for the fuel pump relay though.
is there a difference between a 305tbi and a 350tpi fuel pump. i asked for one from a 350tpi at the parts store, $50 lifetime warranty. and pick it up tommorow.
or i could order a Granetelli 255g/h fuel pump for 120, no warranty, and have to wait 3-4-5 days to get it.
Old Oct 4, 2002 | 07:04 AM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
305/350 TBI - needs around 14lbs pressure
305/350 TPI - needs around 45lbs pressure (LT1 about same)
disclaimer: pressures are close not approximate
Old Oct 4, 2002 | 08:36 AM
tzweelz's Avatar
ok, so im going to get the fuel pump for a tpi then. i should have no problems, it will be regulated and the excess fuel will be sent back to the tank correct? then i should not have to worry about needing any more fuel in the future, i hope.
i would also like to check the fuel pump relay, but cant find it. its not in my chiltons book, and i dont see it around the fuse block.
could it be way up the dash, near the fuel pump, or around the engine?
thanks guys,
Old Oct 4, 2002 | 09:00 AM
Andrew88iroc's Avatar
If it's the same layout as mine The fuel pump relay is in the engine compartment driver's side next to the brake servo. There should be three relays - fuel pump / maf sensor and maf burnoff - the two maf relays will have the same part numbers. Hope you have some luck - I'm still trying to figure out my fuel problem
Andrew
Glowsock
Jul 24, 2025 03:15 PM
mustangman65_79
Apr 14, 2017 05:37 PM
Bryan F
Aug 18, 2015 02:28 PM
Winchester1094
Aug 18, 2015 10:23 AM
Newguy91rs
Aug 7, 2015 09:51 PM
