timming doesn;t change with vac. advance off??
Old Oct 3, 2002 | 10:06 PM
89formula#1's Avatar
Car: 89 Formula
Engine: Carbed 5.7
Transmission: TKO-600
ok guys when i go to time my car i will shoot the light on and see the timming then pull off the vacum advance line goin to the carb cause i thought u where supposed to adjst it with it off. well when i pull it off it doesn;t change the timming. is there somthing wrong here?
Old Oct 3, 2002 | 10:36 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
If your vacuum can is connected to a ported vacuum source then there will be no vacuum to the distributor at idle.
jhawkeye
May 25, 2022 06:33 PM
maroe624
Apr 16, 2017 08:29 AM
ziggy89
Exterior Parts Wanted
Sep 10, 2015 08:44 AM
TheExaminer
Aug 19, 2015 10:07 PM
