Question about 52MM TB
Old Oct 3, 2002 | 10:52 PM
90FormulaL98's Avatar
Car: 1990 Formula 350
Engine: L98 350
I bought one when i rebuilt my motor and i had to adjust the screw out to make my car idle. So i checked the TPS the other day and at idle it is at .9 instead of .5 where it is supposed to be. Could this cause problems?
Old Oct 4, 2002 | 12:30 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
TPS voltage should be 0,54 *-0,075 v.
/N.
Old Oct 4, 2002 | 11:52 AM
Engine: L98 350
So should I adjust the TB back to where the voltage is .54? If i do that my car wont idle. I cant adjust the TPS so I dont have many choices.
Old Oct 4, 2002 | 01:34 PM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
Why cant you adjust the TPS??? If its not idling right, make sure the IAC is adjusted properly first, then after that you can mess with the minimum idle speed...but if you have it adjusted for a higher idle, the TPS is gonna go up too... But you should be able to adjust that...unless im missing something. Oh well..just my ideas..check it out.
Old Oct 4, 2002 | 01:36 PM
Car: 86 Trans AM
Oh wait..my mistake. I didnt realize there were TPS that you couldnt adjust.
Old Oct 5, 2002 | 03:13 PM
Engine: L98 350
No problem i am going to adjust the IAC but do i need to close the TB to were it reads .54 volts and then set it or set it were it is now?
Old Oct 5, 2002 | 03:25 PM
Car: 86 Trans AM
Hmmm...well, Im gonna say what I think, but Ive been finding that the 90's birds are alittle diff. I have an 87, so here is what I did. First, I think the IAC is set on its own. In other words, take it out, set the pintle distance then stick it back in. Thats how I have to do it. Then, since you cant adjust your TPS, Ide imagine the only way you can do it is by adjusting your TB closed til the voltage is right... The TPS instructions I got with my new TPS said anywhere from .5 to .8...but most people will tell you to keep it around .5. See if adjusing the IAC helps tho, you might be able to drop that idle screw back some and get the voltage down. If Im wrong, yell at me.
Justin
fasteddi
Sep 10, 2015 09:32 AM
masonta
Sep 1, 2015 06:40 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
