Going to the track in 3 weeks. What to do before I go.
Old Oct 3, 2002 | 11:43 PM
87transam5.7tpi's Avatar
I'm going to go run my car in the 1/4 for the last race of the year in 3 weeks. what are some things I should do before I go? I'm giong to get my SFC's on before I go. anything else that should help me out? thanks......oh and my mods are in the list.
Josh
Old Oct 4, 2002 | 01:52 AM
Sauron91's Avatar
nawws!
Old Oct 4, 2002 | 08:34 AM
Vader's Avatar
Re: Going to the track in 3 weeks. What to do before I go.
Originally posted by 87transam5.7tpi
... anything else that should help me out? thanks......
Yeah. Take out the stereo. The extra 180 lbs. of magnet and steel are going to cost you a couple of tenths for sure.
Old Oct 4, 2002 | 10:37 AM
Xenodrgn's Avatar
Remove any weight from the car you can afford... all stereo stuff, seats, jack, tools, garbage... vacuum the dirt outta your rug, start youself on a diet... ect...
Remove the front sway bar before you race to help weight transfer
Read the debate on the drag racing board on burnouts on street tires... seems we'ev changed things... people are now saying steet tires need smoke to hook... Experiment...
Do a complete tune up, change your oil, run some TB cleaner through it, top engine cleaner... anything you want... make sure it's running like a top...
Fix exhaust leaks...
If you know your tires are out of alignment, get them aligned to the specs that can be found on this board... no need to go full drag alignment, just a decent street alignment will work... your car can go faster easier if you don't have to fight to keep it going in a straight line...
some argue with me, but I say take off your AC and PS belts... if you can live with no PS coming back to the lanes... otherwise you might as well leave them both on...
Study other racers on how they launch and how they stage... watch as much drag racing as you can... ask questions...
Good luck!
Old Oct 4, 2002 | 10:59 AM
jichniow's Avatar
Car: 89 IROC-Z
Engine: 6.0L LQ4
Transmission: 4l60e
Axle/Gears: 3.70
Raise tire pressure in the front and lower it in the rear.
Go on the last yellow!!!
Bubbajones_ya
Oct 25, 2015 08:01 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
jaridjohn
Oct 5, 2015 07:01 AM
Numbah-1
Oct 2, 2015 08:27 AM
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
