code 13... bad fuel pump?
ok i was driveing home and all the sudden the car started to sputter when i push the gas. i hit a red light dammit now i have to pump the gas in order for it to gain motion again, the lights on the dash seam to dim as i did this, slowly slowly i made it home, this morning i went to start it to check the fuel pressure, i could hear the fuel pump start up but it seam to run a little longer then normal the the car would turn over but not start, i turned off the car and the fuel pump ran for an extra 3-4 min. i also got a code 13 oxygen senser running lean. does this sound like my fuel pump is bad?
by the way i been having problems with my ignition system i just replaced my modual.
