what should IAC value be at highway speeds??
Old Oct 4, 2002 | 05:30 PM
breathment's Avatar
say around 70MPH holding a constant speed.. what should the value be? or does it matter since the throttle is open anyways?
Old Oct 5, 2002 | 12:27 AM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Re: what should IAC value be at highway speeds??
Right. It's just for idle.
AJ
Old Oct 5, 2002 | 03:10 AM
ViciousZ's Avatar
Car: 91 camaro
Engine: 383
Actually, it should be pretty wide open when you are cruising. It dashpots itself so when you let off the gas and come to a stop, the engine will idle back down slowly. I really don't know the number you should expect from a scan tool, but I'd guess it's pretty high, like around a hundred or so.
IROCtometal
Sep 9, 2015 10:01 AM
Jk_Under
Sep 8, 2015 08:13 AM
84 TA NV
Sep 6, 2015 08:02 PM
greenyone
Sep 2, 2015 03:39 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
