New Battery Time. How Many Amps ?
Old Oct 4, 2002 | 05:45 PM
GTA88's Avatar
Hi,
I need a new battery since the one I have is 6 years old, and just died (bad cell), and won't recharge.
I was all set to get the cheapo $29.00 Walmart 510 cold cranking amps EverStart battery, when I noticed a battery catalog at Walmart said my car ( 88 GTA 5.7 TPI) was supposed to have a battery with 630 cold cranking amps.
The old battery had 650 cold cranking amps, btw.
Does it really matter if I get the 510 cold, versus the 630 cold ??
Will there be any performance difference?
Thanks,
GTA88
Old Oct 4, 2002 | 05:53 PM
rjmcgee's Avatar
I would get what ever is recommended or larger.
Personally, I prefer the red top Optima dry cell batteries but they are about $100 more than you are looking to spend.
Old Oct 4, 2002 | 06:00 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I got my Everstart Maxx (yellow) from Wal-Mart $60 or so, 1000 CCA.
Old Oct 5, 2002 | 09:54 AM
Sciguyjim's Avatar
Go with the highest cold cranking amps you can get, and still have a battery that will fit in the holder.
Old Oct 5, 2002 | 11:34 AM
HIL87TA's Avatar
Engine: LG4
I think the power opts. u have the beter the battery u should get; I have pwr; trunk, windows, door locks ,ant. top line delco.
Old Oct 5, 2002 | 08:07 PM
GTA88's Avatar
Thanks for the suggestions. I got the 630 cold cranking amps ( at zero degrees F ) from Walmart for $39. I took it to a parts store and had them test it, and it tested out at 901 cca at 75 degrees F. The car starts up a lot easier now.
GTA88
HP52TA
Feb 3, 2018 10:51 PM
apie2546
Sep 24, 2015 12:27 AM
sahlomonic
Sep 20, 2015 07:15 PM
gta892000
Sep 16, 2015 12:37 AM
1Aauto
Sponsored Vendors
Sep 8, 2015 11:14 AM
