Trouble code 43?
Old Oct 5, 2002 | 03:55 PM
90FormulaL98's Avatar
Car: 1990 Formula 350
Engine: L98 350
Trouble code 43?
What all does that involve? It does it when it is cold and I first start it up. The car backfires and is sluggish.
Thanks, Gary
Old Oct 6, 2002 | 09:03 AM
Vader's Avatar
DTC 43 - ESC module/circuit problem. Detonation sensor problem.
I'd start by checking the electrical connector at the detonation (knock) sensor on the right side of the engine (near the starter). Unplug it, clean the connecctors, and reseat the connector fully. If there is no obvious problem there, you should also check the connections at the distributor. IIRC, there is no separate ESC module on the '90 cars, when the function was incorporated into the ECM. Since ECMs are quite reliable, I'd suspect a poor connection or failing detonation sensor.
Old Oct 6, 2002 | 11:31 PM
Engine: L98 350
Thanks, I will check the kncok sensor tomorow.
Gary
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
Lmancha96
Sep 25, 2015 08:11 PM
