vader , help?
Old Oct 6, 2002 | 05:32 AM
HIL87TA's Avatar
Engine: LG4
vader , help?
You seem to know a lot more about my 87 t/a then I. Tried to keep my car pretty much factory.[ every day driver up until recently] Car would not pass [nj emiss][2-times] most work i try to do myself [ much better w cars w no O B C] Had buddy check compt for codes nothing abnormal .I 've put in o-2 sensor, cat , vac lines replaced, I herd some where that to check egr [while car is running u dis connect the lead hose and the idle will get erratic] I had my old lady rev the engine up and keep it a one level while I did this and I saw no difference in idle. I already have new egr I'll put in this week [some time] . Other then the trans - everything is new [ tune -up,motor -less than 40,000 -rblt carb. The readings were HC143 ,140 standard[didn't miss much their]NOX 2552 ,standard is 1046, [I was way off] . They say if i get new egr they will pass me , but i want the car to run properly [ when cat was put in my buddy said it was badly blocked] Any help from u would be great . 1 more thing before had work on cat done on my dash on right side bottom [where temp gauge is this little lite would come on sometimes when ] strange go on for less then 1/4 mile then go off only on hwy driving yet no code came up on cmpt don't remember that lite in my old 85T/A .i have a 87t/a 5.0 4 bll.
Old Oct 6, 2002 | 08:47 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Just to let you know, Vader is the past has said sometimes he does not respond to posts directed towards him, he prefers it thru PM.
Old Oct 6, 2002 | 08:54 AM
ede's Avatar
ede
yep it's always a bad idea to ask for someone by name when all you want is help with a problem. there's always half a chance mark or me could of answered your question, but since we ain't vader we never bothered.
Old Oct 6, 2002 | 09:26 AM
Car: 99 Formula
Axle/Gears: 342
Maybe 1/2 chance with you, only about 1/10th chance of me answering it.
GTAlover
Sep 19, 2001 09:03 PM
Timmys88Z
Aug 1, 2001 12:21 PM
