Update on problem.
Old Oct 7, 2002 | 01:19 PM
TBI305Camaro's Avatar
Update on problem.
Ok without the rocker arms on cyclinder #1 i have compression so the valves were being pushed down. The compression is 220ish. Another valve was 182...isnt that to far apart? Also #1s valves werent that tight...i could twist the pushrod and jiggle the rocker arm. Also the lifters appear to be working because the pushrods are going up and down.
Ok that takes care of one problem but should i still pull the head to see what that awful noise was? what should I do know?
Old Oct 7, 2002 | 06:02 PM
ttt
Old Oct 8, 2002 | 01:59 PM
No4NJunk's Avatar
Car: 87 Grand National
Engine: 3.8 SFI Turbo
Transmission: BRF 200R4
compression sounds about right. Thats a bit of a difference but not horrible. As for the sound, pull the intake and check the lifters. Check for the circular wear pattern on the bottom of the lifters (could be collapsed lifter, esp if not spinning). Can't remember what exactly your problem was but I have a faint idea. Check springs for bind, studs (if there pressed one could have pulled out), and see if your rocker geometry is right. Also not sure what all you have but make sure your rocker hasn't been bottoming out. Too much cam lift on too light of a spring can cause problems.
Old Oct 8, 2002 | 04:33 PM
Bort62's Avatar
What exactly is the Motor's Setup anyway ?
Falcon50
Aug 22, 2020 03:26 PM
RS Reaper
Oct 17, 2018 07:52 PM
FormulaEngland
European Region
38
Jul 17, 2016 07:33 AM
HoosierinWA
Oct 7, 2015 10:15 AM
Aaronv808
Members Firebirds
Sep 30, 2015 12:55 PM
