fuel pressure wavering +- 1 lb..
Old Oct 7, 2002 | 10:46 PM
breathment's Avatar
ok.. my fuel pressure will jump between like 41 and 43 psi.. like the needle will like jump back and forth at a max of about 1 psi.. (with the vaccum hose disconnected..) and at the same time you can FEEL a ticking in the guage when u are holding it that follows the needle movement. the injector tick pretty loudly also. but i heard that was just a sign of good working injectors. oh and also the pressure doesn't always jump back and forth.. like usualy only once its warmed up or been idling for a few minutes.. could this be the sign of a stuck injector??
Old Oct 8, 2002 | 01:07 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Do you have a fluid filled fuel pressure gauge? If not it is normal for the guage to fluctuate.
Old Oct 8, 2002 | 04:18 PM
breathment's Avatar
but this isn't like permament mounted guage or anythiing.. this is while holding it in my hand.. and i can also feel the ticking that goes along with the needle movement.. and also it doesn't also move.. just at certain times...
Old Oct 8, 2002 | 06:51 PM
'87FAKE-IROC-Z's Avatar
Car: Damn
Engine: This
Transmission: New Stuff
Mine does that too. I'd imagine the pulsating is just when the injectors fire. Remember on our cars they fire 4 at a time, which seems would create that less then more pressure occurance.
I've also heard that it can be a sign of a weak fuel pump, but I've been driving it for a few years like this now.
92camaroJoe
Jul 29, 2023 07:57 PM
R3500
Aug 17, 2015 12:16 PM
wayshegoes
Aug 17, 2015 12:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
