Need some experienced help NOW!!
Old Oct 8, 2002 | 09:31 PM
redcamaro83's Avatar
Car: 86 Z28
Axle/Gears: TBD
i am two days from buying a 1990 camaro RS
the column is messed up so the ign key does not work niether does the screw driver method.
i have no prob buying new column
but want to start car prior to buying it
how can i get around the factory alarm (chip in key?) so i can either driveit home or check condition.
if you feel this is sensitive info e-mail me.
jonathan-2fast4u@juno.com
Please help me i really do need help the car has 305 if that helps
not sure as to whether it is tpi or tbi
HELP!!!!
Old Oct 9, 2002 | 06:44 AM
1986redbird's Avatar
check the tech. articles on the main page, they have one there about overriding the VATS system.
Old Oct 9, 2002 | 10:01 AM
Car: 86 Z28
Axle/Gears: TBD
thanks if anyone else has info don't be afraid to post or e-mail
Old Oct 9, 2002 | 03:59 PM
Car: 86 Z28
Axle/Gears: TBD
update....oh shht!!!!!!!!!!
ok here the deal the current owner says the chip is missing from the key. what do i do now?
Old Oct 9, 2002 | 05:11 PM
rezinn's Avatar
Why the hell would you buy a car you can't even start? Do some searches for the info you need, it's here somewhere.
Old Oct 9, 2002 | 06:16 PM
RBud350tpi's Avatar
http://www.sethirdgen.org/vats.htm
antman89iroc
36
Jan 31, 2016 08:42 AM
cheesehomer
Dec 31, 2015 08:48 AM
BrianI
Oct 3, 2015 12:57 PM
mfp189
Sep 27, 2015 09:25 AM
PeteK825
Sep 22, 2015 10:47 AM
