sticky throttle
Old Oct 9, 2002 | 12:04 PM
irocaz28's Avatar
sticky throttle
I have an 88 iroc 350 tpi. the trottle was sticking so i changed and reset the t.p.s.. While i had the sensor off i sprayed car choke cleaner all around the butterflies to clean off any crap that may have built up and possibly keepin the trottle from closing. i had a lot of black stuff flow out of it. Is that good? After putting it all back together i started the car and the trottle still sticks at 2000 rpm's. when i drive the car and get on it, it takes forever for the needle to go back down and then it sticks at 2000 again. Any advice on what it can be?
Old Oct 9, 2002 | 07:42 PM
RBud350tpi's Avatar
Clean the IAC and set minimum air.
https://www.thirdgen.org/newdesign/tech/tpimod2.shtml
Old Oct 11, 2002 | 07:58 AM
felo72's Avatar
I had the same problem, I still recommend cleaning the IAC, but spray liquid wrench in all 4 sides of the butterfly shaft. What happened is when you sprayed choke cleaner, it cleaned out all of the old lubricant and now it doesn't have any. Try it and you'll definately notice the difference. I didn't believe it when I heard about it on this board, but was amazed as how easy it was to fix. I tried everything until I heard about it. Let me know your results.
Old Oct 11, 2002 | 02:11 PM
irocaz28's Avatar
thanks man. i was actually going to do that before but i havent gotten the chance. now that i kno it worked for u im sure it will work for me. thanks man.
Old Oct 11, 2002 | 06:25 PM
1987gt's Avatar
Car: 1989 GTA
Engine: 350 TPI (Many Mods)
rbud350tpi is correct i had the same problem and i used a lillte liquid greese and it works great it started doing it again after a couple of weeks but i sprayed it better and i havent had a problem yet just make sure you move the throttle while you spray it in their so it works its way in.
Old Oct 12, 2002 | 01:45 AM
RBud350tpi's Avatar
felo72 gets the credit here. I sugested cleaning the Iac and setting min air.
Old Oct 12, 2002 | 09:36 AM
1987gt's Avatar
Car: 1989 GTA
I stand corrected felo72 deserves the credit here my appologies.
Pac J
May 17, 2020 10:44 AM
RedLeader289
May 28, 2019 01:47 PM
Z28/ZR1
Oct 23, 2015 01:04 PM
HoosierinWA
Oct 7, 2015 10:15 AM
dusterbd
Sep 29, 2015 08:40 AM
