Timing wont advance
Old Oct 10, 2002 | 10:06 PM
88305tpiT/A's Avatar
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
Timing wont advance
my problem is simple -- the timing wont advance with RPM.
it is an 88 TPI and all the ignition stuff is stock so that I can find the problem (ie racing ignition disconnected).
I have a remote mount coil ignition.
I dont know what tells the distributor to advance the timing as this is most likely the culprit.
please help
my car is dying because I have to run the timing at 20* advanced all the time.
Old Oct 10, 2002 | 10:52 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Change the module inside the distributor.
Old Oct 11, 2002 | 07:59 PM
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
changed it -- doesnt help.
timing still wont advance.
Old Oct 11, 2002 | 09:28 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
there is probably a break in the wire that sends the signal to the module to have it advence. Check the four wire connector int he rear of the dist. for loose wires. I dont remember which wire it is (black/purple?) that sends the signal to the module to advance the timing, but if you back probe it, you should be able to see the voltage increase as the rpms increase. If there is no voltage, there is a break in the wire or maybe a problem with the ecm.
Old Oct 13, 2002 | 04:18 PM
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
THANK YOU
That is precisely the information that I wanted to know
Amillionoh7
May 24, 2020 08:01 AM
nhra-trans-am
Southern California Area
Sep 17, 2015 10:16 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
Thirim
Aug 9, 2015 06:19 PM
djmarch
Aug 9, 2015 05:27 PM
