coolant disapearing
Old Oct 11, 2002 | 08:06 PM
blaznbrd's Avatar
Car: 90 T/A GTA
Engine: 350 tpi
coolant disapearing
k i fill my coolant, and like 2 weeks later it's gone. it is running warm because my front air dam is broken and i have the trans am front on. i'm putting the new air damn in 2night. could me running hot suck the coolant out. i already changed the heater care, water pump and all the hose's from the radiator. and there are no leaks any where. i run at 220 like all the time how hot is that. should cool down alot with front air damn right?
Old Oct 11, 2002 | 08:10 PM
RJR99SS's Avatar
220 is hardly a desirable temperature, but its pretty common with 3rd gens.
Does your car smoke alot by any chance? you notice any leaks? How about the thermostat housing? is there alot of marks around it that look like burnt up liquid?
Old Oct 11, 2002 | 08:16 PM
blaznbrd's Avatar
Car: 90 T/A GTA
Engine: 350 tpi
only smokes on start ups, somtimes. and no leaks
Old Oct 11, 2002 | 08:26 PM
RJR99SS's Avatar
what color and mass would you describe the smoke?
Bluish and normal mass?
Whitish and normal mass
Whitish and leaving a LARGE cloud
Old Oct 11, 2002 | 08:33 PM
rezinn's Avatar
When I worked at kragen I had this guy coming in that told me his coolant and oil had been evaporating from his car - but it didn't burn any coolant or oil. It doesn't make sense otherwise, but I couldn't convince him and ended up selling him all kinds of stupid additives that did absolutely nothing, and I told him that too.
There are three things that could be wrong. 1. your cooling system was not full to begin with because it was only filled up, not run to get air out of the system. 2. you have a leak 3. it's burning.
220 is pretty hot, but you're not really hurting anything unless you add another 30 degrees to that for an extended period.
Old Oct 12, 2002 | 12:43 AM
blaznbrd's Avatar
Car: 90 T/A GTA
Engine: 350 tpi
well cured the temp prob it's running like 190. the smoke is white and not alot just for acouple seconds. but it doesn't happen every time i start the car. wel i had a leak an it trained almost all me coolant, and i didn't let it run. so i'll let it run 2morrow and see what happening. i replaced the broken pipe 3 days ago and have filled it with a 1 1/4 things of coolant. thanx guys
sheachopper
Jul 31, 2019 11:27 AM
ULTM8Z
Oct 2, 2015 01:25 PM
