Non-thirdgen propane timing
Old Oct 10, 2002 | 07:26 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Does anyone have an idea what the advance curve for a propane-powered 307 SBC should be?
Old Oct 10, 2002 | 08:41 PM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
Found a big tank for the truck?
Old Oct 10, 2002 | 09:58 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Different truck... the Ford's a 444 Diesel, this one's a 307 Propane GMC.
Old Oct 11, 2002 | 03:49 PM
Engine: 305-4v
All I can tell you is that we used the stock HEI timing curve in my 1979 Impala 350. It worked quite well.
However, if I recall correctly, the advance can be quickened somewhat. Propane has a higher octane rating, so try one step looser on the springs and then advance the timing until it pings, then retard it 2 degrees.
If that works well try the next set of looser springs, etc.
Just make sure the coil is a hot one. More octane equals harder to spark. I remember the day we converted mine over. Two plugs and two wires that worked fine on gas gave up the ghost instantly on propane
Old Oct 12, 2002 | 12:54 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Yeah that's what I hear, propane is around 110 octane or so. I've got access to a good old fashioned distributor machine here too, so it's fun to play with timing.
Old Oct 12, 2002 | 01:00 AM
Engine: 305-4v
The nicest thing, IMHO, is that propane costs half what gas does and still gives you almost 90% of the mpg
I remember buying propane for .08 cents/gallon.
That was 20 gallons at 8 cents = $1.60 to fill the tank :hail:
For you Americans out there, that would be like filling your 20 gallon tank for $1.00 ... pretty hard to take, eh?
Infested
May 22, 2018 11:56 PM
bamaboy0323
Sep 3, 2015 06:07 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
Thirim
Aug 9, 2015 06:19 PM
