timing question
Old Oct 12, 2002 | 03:49 PM
primer84z's Avatar
timing question
ok i hooked my car up to a friends gadget that reads engine rpm and timing, and it showed -8 timing at idle. the car was supposed to get a performance tune up when i had the cam installed. so we set it to about 9.5 to 10* at idle and 38* at around 2200. is this good? i guess that was the reason the car didnt run as strong as it does now.
Old Oct 13, 2002 | 11:58 PM
Rustydawg's Avatar
Car: 86 Firebird
Engine: 355 4 bbl
Transmission: TKO 600
Axle/Gears: 3.73 L/S
Your numbers sound right on the money to me. In fact I would be tempted to keep advancing it until it rattles under load, then back it off a bit.
There's all kinds of torque to be made/lost with ignition timing and the advance curve.
Old Oct 14, 2002 | 12:57 AM
ronterry's Avatar
Car: '94 Corvette
plus, I alway check total advance at higher RPM's greater the 3000rpms. I do this to double check for any deflection of the advance wieghts. Some parts at super high rpms, say @ or greater than 6000rpms will deflect as much 2+ degrees of advance.
Ron
MustangBeater20
Oct 29, 2022 09:20 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
