Block ID
Old Oct 15, 2002 | 12:26 PM
Brian Felts's Avatar
Car: 89 RS 355/ 89 IROC Convert
Engine: Hot Cam 355/TPI 305
Transmission: All 700r4's
Block ID
Well to start off I can't see the casting numbers on the back. The problem is that there is a little oil gally plug just above the timing cover. This is not on my L98 block and I thought it was a tale tale sign of a 4 bolt 350. I just bought the car and am working to fix and repair it. It has the 305 centerbolt heads. I am just looking for a little insight before really taking it down to find out.
Brian Felts
Old Oct 15, 2002 | 12:38 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Look at the casting numbers. Get a flashlight and a little inspection mirror if you have to. It's the only way to make sure of what you've got. Although, that won't necessarily tell you whether the factory installed the 4-bolt caps into that specific piece of cast iron or not, just like having the oil plug won't. Only way to know that for certain is to pull the oil pan. They don't drill extra holes anywhere but the main saddles when they use the other caps.
Old Oct 15, 2002 | 01:00 PM
Yeah I understand that, I did just check and found its a 1 pc. rear main. I just can't get a clean read on the casting numbers.
Brian
sheachopper
Jul 31, 2019 11:27 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
skinny z
Oct 5, 2015 06:23 PM
92projectcamaro
Sep 29, 2015 07:07 PM
dusterbd
Sep 29, 2015 08:40 AM
