hypereutectic vs forged
Car: 86 z28, 87 IROC, 88 sc, 93 z28
Engine: LG4, LB9, LO3, LT1
Transmission: 700r4, T5, 700r4, 4L60
Axle/Gears: 3.73, 3.45, 2.73, 3.42
I dont know much about hypereutectic pistons but i have always heard they dont last very long. I am wondering if i should order hypereutectic or forged with my rebuild kit. Im not planning on useing nitrous by the way. Any opinions? thanks!
Car: 1987 Monte Carlo SS
Transmission: 200-4R
Axle/Gears: 7.625 10 bolt/3.73s
Hypereutectic will be just as good as forged under street conditions. But if money allows, get forged.
hypers are stronger than forged and for stock replacement type pistons are lighter. they are also a lot more brittle and break when exposed to preignition. they also expand a lot more than cast or forged and require larger end gaps.
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Here's some info I found at www.carcraft.com about Cast, Hypereutectic, and Forged pistons.
Pistons: To Forge or Not To Forge
Pistons (or slugs as they are sometimes referred to) reside in the cozy inferno under the combustion chamber of the cylinder. Attached to the small end of the connecting rod, these units move up and down in the cylinder at tremendous speeds pushing air in and out of the engine. Most engines, even performance-minded motors, come from the factory with some sort of cast aluminum pistons. There are both high- and low-pressure cast pistons and their resistance in a hostile cylinder environment is relative to the density of their composition and its related resistance to friction and pressure. Simply put, cast pistons cannot withstand the levels of heat, friction, and speed that aluminum forgings, with their denser mass, can survive. Casting is a mass production process that allows for minute imperfections and porosity in the piston. Cast pistons, which are stock in popular motors, are often high-pressure castings with friction-fighting coatings to survive more revs. The advantages of cast pistons are that they’re lightweight, there’s a lower thermal expansion rate compared to forgings, and they cost less. For most mild performance applications, these castings are quite effective due to their lower heat conductivity and tendency to reflect heat back to the combustion chamber.
Hypereutectic pistons became the rage in the early ’90s as they offered the reliability and light weight of cast pistons but were resistant to higher cylinder temperatures. These pistons are cast with a material high in silicone content to achieve the low expansion rate and cylinder wall tolerance of a common cast piston, with near forged piston strength. Hypereutectic pistons are ideal for high-performance, naturally-aspirated combinations that won’t suffer under the strain of power adders like turbos or nitrous, which can quickly decompose this strong, but inflexible style of piston. These pistons are priced in between pressure castings and forgings.
Forging is a process that creates a solid chunk of uniformly grained metal. The details, features and sizes are then precision-machined from this piece to create a near jewel-like finished product. Forged pistons come from the aftermarket in various sizes, pin and ring locations, and dome configurations. Forged pistons signify a serious commitment to the engine’s performance potential; their ability to withstand heat and pressure at greater speeds inevitably means greater outputs than cast pistons. Most forged piston manufacturers offer two different alloys as the base material for the forged pistons. Forged pistons become stable at higher rpms, once their material expands, but can cause noise as they slap around in the cylinder walls at low speed when cold. The aluminum used for forged pistons differs in its proportion of silicone and copper, and thus offer different expansion rates. Additional silicone in a 4032 grade alloy yields a piston with lower heat expansion properties that maintains a tighter piston to wall clearance. Another grade of aluminum, 2618, contains less than one percent silicone with a higher content of copper. The composition of such pistons permit greater expandability and require greater piston-to-wall clearances, making it suited for the extreme heat and pressure caused by high-boost turbos, superchargers and loads of nitrous.
Here's a quote from Speed Pro, which are the pistons I'm using in my 350 build.
Speed-Pro’s cast hypereutectic material is a relative newcomer to the performance market, and has several attractive features. Our hypereutectic pistons operate perfectly with standard ring end gaps, and have conventional ring land locations. When compared to traditional cast pistons, which are not designed for performance use, the hypereutectics are significantly stronger, particularly in the highly loaded ring land, skirt and pin bore areas. Our FM244 Alloy contains 16.5% silicon, and has excellent tensile and fatigue strength. This material’s improved thermal characteristics, it’s greater hardness, and the increased resistance to scuffing permit tight bore clearances which help minimize noise on cold engine start up. This quiet operation, along with a lower cost are the primary advantages over a comparable forged piston. These pistons are an excellent choice for street performance, for “claimer” oval track engines, and for bracket racing use. They will also work well in moderate supercharged applications, and are suitable for towing and marine use.
Are they lying about not needing larger ring lands and larger gaps?
AJ
i'd follow the manufactures recomendations, i never saw anywhere in what you posted to make me think they weren't as brittle as any other hyper. are you confuseing high strength for not being brittle? if so consider this take a coat hanger clamp it in a vise and smack it with a hammer, it'll bend. try the same thing with a file and you'll have at least 2 pieces. by most standars we'd all agree the file is the stronger of the two metals, and both are steel.
Car: RS
Axle/Gears: 9" for the ladies
re
Hyper craps break when you boost them, spray them or get detonation.
TRW forged pistons can be found on ebay new for about the same price. I see no advantage to the hypercraps
The way you guys describe them makes it sould like they're worse than stock cast!!!!
That's true with any piston if you go beyond what they're made for. Hell, stock cast pistons can take ~125-150 HP shot of juice. Hypereutectics are good for more than that with ~225 being the norm. I don't know what the limits are of forged pistons, but it really doesn't matter if you get too much detonation. Any piston will fly apart if that happens.
Why do you keep saying that about the ring end gaps? That's so untrue. These aren't forged pistons. They don't swell under heat or contract while cool like forged pistons do. Forged pistons are the ones that you have to watch the ring end gaps with. Hypers don't take any more ring gap than stock cast do.
Granted, forged pistons are MUCH stronger than hypereutectic, but they're also MUCH more expensive. Hypereutectics have their place, just like any other automotive part. But you guys make them sound like they're inferior to stock cast pistons. Why?
You left out one minor detail.
You have to hit the file A LOT harder to get it to break than it takes to get the coat hanger to bend. And I can bend a coat hanger back and forth fast enough to make it break from stress. Can you do that with a file?
AJ
they just don't live with detination or incorrect ring end gaps
You have to hit the file A LOT harder to get it to break than it takes to get the coat hanger to bend. And I can bend a coat hanger back and forth fast enough to make it break from stress. Can you do that with a file?AJ
not if the file and coat hanger are the same size, files aren't hard to break. aj you sure you've installed a set of hypers? all the ones i've used need 40% increase in end gap over stock, but i believe there are some hypers that will run stock end gaps, but i've not used them, and hypers do transfer heat a lot more than cast or forged, that's the reason behind opening up the end gaps.
the true test is to take a hypereutectic piston and a forged piston .... with one in each hand, drop them on a cement floor from the same height, say 6 feet.... U will know which one you want after that.... there really is no contest durability wise, I think you can live with 5 minutes of inaudible piston slap at idle in return for the greater amount of abuse they can take.
the forged are stronger for turbo or nitrous. but on the same note in comparison to a hypereutectic piston they are much heavier and dont expand into the cylinder walls as well... if you are natuarally aspirated with under 11:1 compression go with the hypereutectic otherwise go forged.
Guest
Posts: n/a
Hypereutectic pistons are more brittle, its an inherent quality because of what they did. In general, materials that are stronger are also more brittle. Using the coat hanger example, thats sorta what a forged piston will do. It will deform rather than break right away. The strength limit is somewhere past where it starts to deform, making it a little more tolerant to abuse. A hyper piston when it reaches its strength limit just gives up and breaks.
As for the ring end gaps, that is all dependant upon the piston design and where the rings are. The only reason the hypers expand less is because the alloy doesnt expand as much under the heat its subjected to. This doesnt make it run any cooler or make it transfer less heat to the rings, it just means the material doesnt expand as much. Two totally different things.
Anyway, if you are planning on boost or nitrous, I'd recommend using forged pistons. Otherwise, the hypers will work just fine.
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
You left out one minor detail. You have to hit the file A LOT harder to get it to break than it takes to get the coat hanger to bend. And I can bend a coat hanger back and forth fast enough to make it break from stress.
my machinist tells me that hyper's expand alot less which is why they allow you to run tighter piston to wall clearances.
hyper pistons are all i have ever used. Joined: Jul 1999
Car: RS
Originally posted by AJ_92RS
The way you guys describe them makes it sould like they're worse than stock cast!!!!AJ
Stock cast pistons changed over the years anyway. In 90 they went to a lighter version. I think i would spray on a cast piston before a hypercrap piston.
Hypercrap are good for ONE thing. Tight tolerances that don't change. Thats it.
You can buy a light forged piston if you have the money.
I have TRW's I droped a valve guide in to the engine while it was running. Needless to say everytime the piston came up it smashed the guide between the head and piston. I drove it home. Rebuilt the engine and reused that same TRW piston. It had minor nicks it, nothing more. That was last year.
A hypercrap would have shatterd, went down in to the pan, went through the oil system, while the rod punched a hole in the block and destroyed the crank.
hypercrap are an all or nothing piston. They are together are they are not. Forged will distort before breaking.
Car: RS
WOW I provided useful insights based on actual experiance and you provided a 'rolleyes' smilie face.
Could you maybe add a 'doh' smilie face to back that up?
Or how about you take a solid peice of metal, put it in a cylinder and run the engine using a hypercrap piston. Tell me what happens when it breaks.
Allow me the honor
And a cast piston wouldn't?
AJ
Car: RS
madmax,
Allow me the honor
AJ
madmax,
Allow me the honor
AJ
for not knowing what you are talking abouttwo
for being the second person in a row.Wouldn't know what the cast, piston would do. Never said I did.
Would take it over the hypercrap ones.
I DO know my TRW forged pistons didn't break under that situation. I also know it was reusable.
So if you don't know if the cast piston would have broken, then how would you know that the hyper would, when it was a forged in the engine?
And I'm the one who doesn't know what I'm talking about?
AJ
AJ
Car: check
Engine: check
Transmission: check
Re: hypereutectic vs forged
How much peace of mind will they provide? A lot.
The ony time I wouldn't use forged pistons is if it was a totally stock 150hp V8 engine. Here not only would I use stock cast pistons I'd reuse the stock valves too.
RBob.
since it may be of use sometime i'll give you all a quick how to for testing metal brittleness, called a sharpie vee notch test. i piece of metal is prepared by milling to a square about 3 inches long with a vee notch about .125 deep in the center. it is placed in a fixture and a weight is droped on it, sort of like a sledge hammer on a pendulum there is a scale to read how far the hammer moves upward after it hits the test piece this reading is equated to how brittle or ductile the metal is. how hard the hammer falls is controlled as is the size of the test piece, often the test piece is frozen in liquid nitrogen. you might be able to better picture how a file and coat hanger would preform during this test and see that even thought the file would test much harder on a hardness test it would break much more easily.
AJ
AJ
The expansion of the piston has nothing to do with the required ring end gap. What causes a hyper to require more end gap is the fact that it reflects heat, causing everything around it to run at a hotter temp, which will make the rings run hotter and expand, necessitating a looser end gap. The reflecting of the heat is good for power output however. The less heat absorbed by the piston, the more there is in the chamber, which will create slightly more cyl pressure pushing down on the piston. Hypers work good for their intended purpose, but in a blown/turbo/nitrous etc engine, you have to be careful, as they will not tolerate any "mistakes" with the tuneup, and they will melt and/or break alot easier then a good forging. I used some hypers in the past in circletrack apps with very good success. Its all about the correct application of parts.
Bob
Car: 82 Z28
Transmission: TH350
OK....
All you guys are right.
Hypers are useless.
They're junk.
They're a waste of perfectly good aluminum.
Cast stockers are better but forged should be the only thing anyone ever uses.
Forged pistons are the only ones that can be used with boost or spray.
A file is more brittle than a coat hanger.
There........ are all of you happy now? I agree with all of you. Is that what it takes to get you to STFU and make you think that you're right? If so, consider it done.
AJ
Hypers are useless.
They're junk.
AJ
AJ
I could really give a **** less if you agree with me or not. Someone asked a question, and i was giving him the information i thought he needed. I at no point said they are junk, they just have limitations, much like anything else. And i will STFU when i feel like it. I dont need someone to "make me feel im right". I do engines for a living (extremely high end engines, btw) and have a pretty good idea what im talking about. No one here really got into a flaming contest with anybody, so the last post was a little offensive. If it was not meant to be, then my appologies.
Bob
Bob
LT1Formula
Oct 8, 2015 08:34 PM
roysatikas
Sep 22, 2015 08:15 PM
Andrew Prakash
Sep 8, 2015 11:48 AM
aluminum, cast, forged, hypereutectic, hypereuteric, hyperutectic, kits, lo3, ls1, piston, pistons, rebuild, rebuilt, slap, stronger
