Black Smoke
Old Oct 16, 2002 | 09:34 AM
Jyrx's Avatar
Car: Firebird
Transmission: th700
Black Smoke
Lately my car begun to blow out a lot of black smoke, I know that the fuel mixture is then rich, but I have not done anything to the car it just suddenly started to do that.
Also I had to pass the tehnical inspection last week and the CO reading was way high (10 -the machine coul not read any higher numbers), luckily the guy who inspected the car is a friend, and he revved the engine up (2900 rpm!!), wich made the CO drop to a normal level and passed me. Also when I feel the exhaust with my hand it feels wet.
I am not shure jet but I think I am getting horrible gas mileage also! (Havent had a chance to test it jet).
Whats going on?
Please help!
Oh jeah the engine is a 350 with a Holley carb.
Old Oct 16, 2002 | 09:45 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Sounds like it's extremely rich.
I'd check the carb. Your problem is probably a blown power valve, on the primary side. They fail suddenly, when their diaphragm ruptures; often as a result of a backfire into the intake. One backfire can destroy the valve. This valve has a rubber diaphragm about 2 cm in diameter, with fuel on one side and intake manifold vacuum on the other; when it fails, massive quantities of fuel can be sucked into the intake.
It's normal for the exhaust to feel somewhat "wet", since one of the normal by-products of complete combustion is water. Obviously the more fuel the car is burning, the more water there will be; so it may feel more "wet" than it should.
Old Oct 16, 2002 | 11:38 AM
Jyrx's Avatar
Car: Firebird
Transmission: th700
:hail: Thanks, I have to look into that! Any idea is there somesort of a repaire kit available, and where can I get it?
Old Oct 16, 2002 | 12:20 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
If that's what it is, you just need to replace the power valve. You should probably get a rebuild kit instead, since you'll probably need some gaskets too, and the valve and gaskets are all included in the kit.
http://www.holley.com/HiOctn/ProdLine/CarbList.pdf
to find the kit part # for your carb. Summit, Jeg's, etc. will have the kit.
Old Oct 16, 2002 | 02:54 PM
Jyrx's Avatar
Car: Firebird
Transmission: th700
Thanks for all your help!!
gta892000
Aug 11, 2019 11:16 AM
Stryker412
Sep 20, 2015 06:59 PM
m00n420
Sep 11, 2015 02:39 PM
Accerrito22
Sep 5, 2015 09:34 PM
Out-Cast
Canadian Region
Sep 4, 2015 10:13 AM
